Which slot on a 37EX524 Bravia is the correct connection point for a SKYPE camera (CMU-BR100) as the top USB slot is already in use by a Wireless Lan ?
Nothing in the camera's installation instructions or the website helps !
Many thanks.
Solved! Go to Solution.
