Sondbar HT-S100F/SF150 Compatibility
Arnold56
I bought this soundbar assuming it would be compatible with a Sony Bravia tv but the HDMI jacks on the tv do not look like the illustration in the startup guide and I can't see how to connect it. Can the soundbar not be used with this tv?
IamNic
Hello @Arnold56,
as long as your TV (which model is it by the way) has a HDMI ARC port, you can connect the soundbar via that port.
Alternatively the soundbar also has a Toshiba Link (TosLink) port, which will be called "optical" on the port itself.
You can connect to that as well.
- Nic
