Sony 65xd8599, sound bar htct790, Sky+box
dhanpal.panwar
Hi all,
can you please advice as how to connect the SKY+ box, soundbar (htct790) to the sony tv (65xd8559). Currently tv is connected directly to sky and soundbar connected to tv throught optical cable. I should be able to control sounbdar through the tv remote.
Can you please help with this setup?
Regards
DP
Hi there
In order to use the TV remote control for the Soundbar, you must use the HDMI port instead of the optical.
Simply disconnect and remove the optical cable and plug a HDMI cable from the HT-CT790 (HDMI-OUT ARC) to the TVs HDMI-ARC port (HDMI 4 on your TV).
Ensure that Bravia Sync is enabled on the TV (by default it is) and ensure that "Control for HDMI" is enabled on the HT-CT790 (by default it is).
Note: When disconnected and reconnecting cables on the TV, its best to turn the TV off first.
dhanpal.panwar
Thanks for your reply. How do you connect the sky box? Does it news to connect to tv or it connects to sound bar?
Please help how to connect all these three.
Ooops - I forgot you mentioned the Sky+ box.  I can be plugged into either to be honest.  However I would plug it into the TV.
Remember to set the TV Speakers to "Audio System" - Can be done via the "Action Menu" button on the TV remote Control.
