Sony Bravia CX52 - running adverts on the screen
profile.country.cs_CZ.title
vpapirnikova
Hello, I bought a TV Sony Bravia CX52, everything works, but sometimes on the sreen the line with description of the TV features appears - sometimes on the upper part of screen, sometimes on the bottom...I can´t get rid of it. It´s really annoying.
Bravia55HX
your tv is set up and displaying in "shop mode", you would need to do a factory re set and set it up again using "home"
4 REPLIES 4
Bravia55HX
How do you do a factory reset to solve the problem of the stupid diplay mode coming up every five minutes?
What a waste of bloody time this performance is. AVOID SONY PRODUCTS - THEY'RE *****
How do you do a factory reset - and why does this happen? Sony are absolute ***** clowns.
Hi there
To factory reset the CX52x series TV:
  1. Press [HOME] on the remote control
  2. Goto 'Settings' and press [OK]
  3. Goto 'System Settings' and press [OK]
  4. Goto 'General Set-up' and press [OK]
  5. Select 'Factory Settings' and follow the on-screen instructions.
