sony Bravia KD-49X8505B
Daxixx
I see the very bad image quality on digital broadcasting through the C-module after update to the latest version PKG2.704EUA ???
Regards,
Hi there
As you are experiencing issues after a firmware update - try doing a factory reset of the tv, ad this can fix many issues.  If that doesnt work, please reply back with what country you are in
SaleZu
I found this post searching solution for issue I have with my TV.
KD-49X8508B
In same time last year, my TV stop working with flashing LED 8 times. I see that recent update is addressing that issue.
My TV was in regular servis of Sony and was there for longer time. After taking back TV I am experiencign same issue as descirbed above. Picture quolity as I can say degradated to certain level and especialy can be recognized by eye on lower resolution image.
Factory reset is not helping also chainging of country.
When I run some of test images destorsion is more visible.
Any adivse what to do?
I am located in Serbia.
Thanks.
BR
Sasa
