I hve just tried to turn on my tv model number above and it has picked a picture then lost it then picked it up then lost it for good but the led has taking to flashing nine times then a small pause then flashing nine times again! Any ideas what this means?
Solved! Go to Solution.
i have no idea on that my friend, best thing to do is ask them when you phone if they can give you any idea,
if your feeling that maybe its time to upgrade then thats your decision.
yes, thats a fault code kicking in, you need to contact your nearest Sony authorised repair centre and tell them what you have said on here, it will then need to be repaired.
Okay cool.
Is it even worth getting it repaired in terms of cost or just replacing?
