MY tv was wall mounted but i have now taken it down. I have the original TV stand but i have lost the stand screws.
I have looked everywhere to find what type of screw they are.
https://www.sony.co.uk/support/en/product/KDL-37S5500
It doesn't even tell you what the screws are in the user manual. Any help would be appriciated
Hi there
According to the spare parts suppliers, the size of the screws are 'M5'. See :
http://www.partmaster.co.uk/search.pl?query=kdl-37s5500&x=0&y=0
Knew someone else would find them easy
thanks for the help.
You're Welcome
