Sony Bravia KDL-40EX713 Stand
stim1986
I've just moved into a property where the above mentioned TV had been left behind.
They previously had it mounted to the chimney breast but i'd prefer it on a TV unit. Is there anywhere I can buy a tv stand to bolt to the back of the TV as they haven't left it behind. I've searched Ebay and Google but haven't had much luck.
Thanks, Tim.
LightFoot
Specialist
Thanks, Tim.
Hi @stim1986. If you cannot find an original stand at a reasonable price then perhaps you could use a VESA stand which will fit any TV. Search VESA stand on a well known on-line retailer.
stim1986
Thankyou! Exactly what i was after!
