Hello
In the past week, my Humax DTR-T1010 Youview box has started displying in Wide-Zoom mode instead of Full 16:9.
I have all the TV's inputs set to Full as a common screen setting, but the Humax (on HDMI 1) is always in Wide-Zoom.
This has only just started to happen in the last week, after the Bravia updated itself.
I can't manage to find the screen settings just for the HDMI input - can anyone point me in the right direction please? It's driving me mad.
Steve
Solved! Go to Solution.
Hi there
Two ways to do this (easiest way is):
Hopefully that should resolve it. I probably should have created these instructions before hand
Hi there
When viewing the YouView on HDMI try changing the Screen Settings using the following instructions:
http://pdf.crse.com/manuals/13LW600114/EN/c_picscrn_size.html
You could try setting the Target Inputs to "Common" which is set to all devices/tv (hence all the same settings)
Hope this assists.
Thanks for the suggestion Quinnicus - when I press the Home button whilst watching the Youview/HDMI 1, nothing happens - I can't actually get to the home screen. Pressing the Options button doesn't do anything either. I've noticed that all of the external inputs are displaying as wide-zoom, so I guess I must have changed something.
I think the Target inputs were Common, but I may have switched away while I was trying to fix the problem - I'll have another go.
Thanks for your help.
Hi there
Thanks again Quinnicus - I would never have found that by myself!
Steve
Hi Quinnicus
I found your solution for the same problem that I have encountered and only had tv 3 weeks!
I have just followed your instuctions and it seems to have done the job!
Regards
Thanks Quinnicus - I would never have found that by myself!
All sorted now but you would have thought it would have been easier to get to menu!
Fogralea
