Sony Bravia Remote Function
purplestarfish
RM-ED045
When I click on Guide and get the list of channels, is there a way to scroll page by page rather than one channel at at time, and can the sound of it be turned off?
Thanks.
Hi there
1 - Scrolling by page:
Sometimes pressing the CH+ and CH- buttons scroll by page - other times it is one of the coloured buttons that may do it.
2 - Can sound be turned off:
Im assuming that you mean the beep beep (system sounds) - as you havnt listed your TV model, im going to guess it is a 2011 Bravia TV, considering the model of the remote control.  Goto the Sound Settings Menu and then turn OFF the Key Tone.  It might be in another menu, but unsure.
purplestarfish
Thanks - green button goes up, red button goes down.  Still can't sort the beeps though - click on iManual button, Settings/Home Menu, Sound, Key Tone, then it simply says "plays sounds as you navigate with the remote" - no option to turn on and off.  However, the advice about the coloured buttons was a great help - far more convenient and far fewer opportunities for beeps!
