Sony KDL-40CX523 - turn off remote beep
lucky1085
Hopefully someone can help, I'm trying to turn off the 'beep' noise that happens when using the remote on my CX523... any ideas, i've had a good scout of the settings, but can't find anything obvious.
Thanks in advance.
KDL-CX520
Thank you for posting your question @Sony forum
In model CX520 (almost similar to CX523) I use the below steps
menu (Home) > sound > scroll down until Key Tone > change the setting to OFF
Regards
KDL-CX520
Regards
Thalamus.
Champion
Hi lucky1085
welcome to Questions & Answers..
Try this..
Go to the Home menu..
Then browse to Settings..
Followed by Sound..
In the Sound menu click on Key Tone..
Select “Off” to turn off the sound and this should also turn off the TV start-up sound..
