Hallo
How can i use my sony remote controller for sky+hd box? i want to use only one contoller. on my previous TV (controller) i had option to switch between TV,BD,PS3,HDbox etc... i cant see something similar on this controller...
or
how can i use sky+HD controller for sony TV?
thx for any answer.
Solved! Go to Solution.
Hi there
Merry Christmas!
This site tells you everything you need to know to get the Sky remote to work with your TV:
http://help.sky.com/articles/program-your-sky-remote-to-control-your-tv
Hi there
Not sure if I can assist on the bluetooth issue, however for the screen mirroring there has been some issues of compatibility between the S3 and Sony TV - But thats for NFC only.
There are a couple of apps on the Google Play store that can/may work. The apps are called Smart Connect and NFC Easy Connect. Give them a try anyhow.
Remember to put your TV in screen mirroring mode.
Edit : Oh, if you are trying to connect the S3 to the TV via bluetooth - It wont work. Only Bluetooth mice work on the TV - nothing else.
Hi there
Merry Christmas!
Hallo and Marry christmas!
Thank you very much i just sort it out
i can see you are expert and may help me with my last issue. i have samsung S3 mobil phone and i cant connect with TV. screen mirroring and bluethoot are not working. is there any other way how to connect it?
thank you
Hi there
