anybody know how to set alarm on widget have tried many times never sounds at anytime !!!!
Solved! Go to Solution.
Go to Alarm widget himself, klick right like options so many times until You come to option set up manualy and try set up manualy. Give as feed back with relevant data , after that. Chack region code in Time zone GMT+...manu-settings-system settings-time zone
http://wwp.greenwichmeantime.com/time-zone/europe/uk/
Regards
Damac
Please refer to your user manual that is given to you with the TV
Regards
Damac
