Sony XF70 Info bar
Moon008
Sony XF70 Info bar
i can not install my smart iptv software in my XF70 model, can anyone help me how to install it??
Pascale_F
Moderator
Hi Moon008,
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Vanilla_
Hi Moon008,
If your TV is not an Android TV, it'll probably have some applications in the Home menu. In case Smart IPTV isn't listed there, this means it's not supported by the TV.
Vanilla_
