sound from TV to home theater
profile.country.fr_FR.title
Samilg
Hi all;
I have Sony LCD KLV-32BX300 which seems to me a really bad copy of KDL-32BX300. Anyway I was inable to use the sound coming from the TV to listen to it via my home theater Sony DAV-TZ210!!! I couldn't find somthing like Audio Out to use it.
Using this link http://www.sony.co.in/product/klv-32bx300
I found this
HDMI™ / Audio In    2 (1 Side/ 1 Rear)
USB 2.0    1 (Side) : Photo (JPEG), Music (MP3), Video (MPEG1, MPEG2 TS & PS)
Component / Audio In    1 (Rear, Composite Input Common Use)
Composite / Audio In    3 (1 Rear Monitor Out Common Use / 1 Rear, Component Input Common Use / 1 Side)
HD15 PC Input / Audio    1 (Side)
Audio Out    1 (Rear)
Bravia Sync is ok via HDMI. Could any one help me?? how can I listen to the sound of TV using my Home theather?
thank you
profile.country.hr_HR.title
DamacizSi
If I see it right, You could use just audio connection with stereo cables, but so will be a sound on Home Theatre just stereo too. HDMI is jut OUT so You can't use it for Your purpose, becouse I can not see optical in on rear site of Your DAV-TZ210.
If You decide to make stereo connection, do not forget to set up TV speakers to OF
http://support.sony-europe.com/tvhc/hc/hcs/dav/dav.aspx?site=odw_en_GB&m=DAV-TZ210
Regards
Damac
Samilg
As a matter of fact, I do not have problems with my DAV TZ210, the problem is that I could not find an Audio Out on my TV klv-32bx300!!!! No Audio Out!! can you believe it no HDMI Out, optical, coaxial or even RCA!! all I could find is 2 RCA IN, 1 composite IN!!!!
could I be wrong???
thank you for your help
profile.country.ru_KZ.title
erangaddd
It is not a big deal mate,
Just connect your TV with Audio system using AV cable (http://i00.i.aliimg.com/photo/267637162/Audio_Video_Stereo_RCA_AV_wire_15m_.summ.jpg).
please follow these steps.
1. plug AV cable to TV's Av-out 1
2. plug the other side of AV to your sound system
3. Go to Menu >> Settings >> Set Up >> AV Setup >> Video1 Input/Output and select Output.
4. Go to Menu >> Settings >> Sound >> Speakers and select TV Speakers or Audio system.
If you choose TV speakers tv will use both audio system and TV speakers unless it uses only your sound system.
