TMR 3D SINC.
profile.country.pt_PT.title
FCBDIAC
TMR 3D SINC.
Hello,
Can anybody tell me what are the main differences between the TMR 3d Sincr. built-in the KDL-LX900 and the TMR BR 100 B used in the KDL-HX800?
THANKS
Message was edited by: FCBDIAC
Catmambo
None as far as I'm aware, the transmitter simply insures that the glasses are correctly sync'd with the TV so it doesn't matter (other than for asthetic reasons) if the transmitter is integrated or separate to be honest.
Catmambo
