Trying to link an already registered BDP S370 to Lovefilm?
magraha33
Hi, i have been given a sony BDP S370 blu ray player from a friend, i am trying to link my account to Lovefilm, but when i go to My essentials account, i cant register the device as it states it is already registered.
How can i re-register it so that i can then use the Love film?
Any ideas
Regards
Mark
Catmambo
Ideally your friend needs to unregister the device on his account first then you an re-register it to yours.
Failing that - ring the call centre as they will be able to get it done remotely although this would take longer.
thanks
5 REPLIES 5
Catmambo
thanks
magraha33
i have spoken to my friend who confirms he has now unregistered the device, the device still says device registered and cant get a a registration code for My Essentials
What do i need to do?
Regards
Mark
Bravia55HX
have you performed a factory re set to clear any bugbears in the system.
magraha33
I have reset to factory settings, but it is still stating device is already registered
any ideas?
Catmambo
Ok, if its still not working, call the call centre and they will be able to assist..
thanks
