Hi
contacted Sony regarding a vertical line on my TV and with it only being out off UK < warranty for a few weeks got told by the repairers that Sony are not going to subtidise the repair in any way, the cost is for the panel itself is 871.00 pounds I was told by the repairers
I am sure A Sony TV should not last 57 weeks should it. costing 1300.00 pounds
Model is KD-55x8505b
Solved! Go to Solution.
Hi there
Please have a read of this thread:
There is an option you can take, but it is with the retailer you purchased it from, under the 'Sale of Goods Act'
thanks for the info peeps
contacted Currys mentioned on the phone for the garantee that I am refering to the EU law regarding getting the TV fixed , and he said thats another thing then! so TV is going to get picked up on this following Monday.
Trading standards...
Hi there
Excellent
They may try and fob you off again, but stick by it and you should be ok.
