Hello, I'm using your TV model and after having read its documentation I wonder if it is capable to let user to record a TV programme on a USB stich (pen drive); if yes how?
If not I do suggest you to add that feature via a software upgrade.
Thank you.
Hi there
USB Recording is available on your TV.
Hopefully this helps
Thank you for your answer.
I wonder if the recorded file may be played on my PC.
Your welcome
Unfortunately the recorded files cannot be played back on a PC or any other device. This is because the recordings are encrypted. This is not just Sony. All manufacturers must encrypt recordings made from a device that has a DVB-T2 Tuner (ie. Freeview HD). Its mandatory to encrypt recordings made from a HD channel, but not from a SD channel. However most manufacturers encrypt both SD and HD recordings anyhow.
Hope that explains things.
Once aain thank you for your contribution
I wonder if someone has found a way to make possible playing a record saved on an USB stich on a PC.
Regards,
Your welcome.
As far as I understand it, I dont think people are too worried about 'cracking it' as many of the shows are available on various other services (ie catch up TV / Netflix etc). Also you probably need some type of engineering degree/skills - and I wont pretend to say I have them as I dont
