TV Stand compatibility
Bennisc
Does anyone know if the TV stand / feet that came with my KDL43 (2016 version) Tv will fit the new 2019 models - unfortunately my kids broke our tv last week and I’m searching for a replacement. I want to keep with a newer version of my current TV, however the feet that are on the new version won’t fit on the shelf we have without an overhang.....any help would be greatly appreciated.
Tags (3)
LightFoot
Specialist
Hi @Bennisc
Why don’t you securely fix a plank of wood on the shelf to match the new stand depth and blend in with your existing shelf. Obviously only if it is 100% rock solid. Reducing the stand width (even if it did fit) sounds unsafe and possibly won’t match the new TV’s centre of gravity.
Bennisc
Thanks for the response, although that won’t work unfortunately. Looks like I’ll have to go with another brand which is a shame as I prefer the Sony.
EdwinaU
Moderator
Hi Bennisc, you can also check the spare parts page here to see if you can find a replacement.
Best wishes,
Ed
