Twitter ticker speed
Lakelandhaze
Hi
I own a Sony Bravia KDL-46EX723 LCD TV and I would like to know if there is a way to reduce the speed at which the Twitter ticker moves between tweets?  At the moment it seems to be every few seconds which is impossible to read properly.
Thanks in anticipation
Tom
Catmambo
Hi, welcome to the boards
Not at the moment, but not sure you can even do this on the main twitter.com site, it just tells you there are new tweets available as far as I'm aware. Are there any mobile apps which add this functionality?
Catmambo
