use touch remote as mouse?!
pingutm
Can nyone help. There are certian android apps that have buttons or settings that the normal remote controll cant access just by touching up down left right on the controller. Is there anyway to bring up a mouse curser and use the touch remote to naviate it?
Relly annoying having apps that you cant access things on 😞 !!
Hi there
Can I assume you have a smart phone or a tablet?  If so, download an app called TVSideview.  This should do what you need to do.
pingutm
thanks, so there is no way to use the touch remote as a mouse? how stupid is that!?!
To be honest, I dont much about touch remote.  I know you can use it as a mouse on the web browser - maybe another forum member can confirm if it works,on other apps
I found a video on YouTube
https://www.youtube.com/watch?v=cdFUyR8FXWM
