What's the difference KDL-42W805A & 42W807A
jowhale
Can anyone tell me the difference betwee these TVs please?
KDL-42W805A
KDL-42W807A
The website spec data is identical!
Hi there
The difference between the KDL-42W805A and KDL-42W807A is the frame colour.  The W805A has a black frame, where as the W807A is silver.
I can understand your confusion, as the website does not clearly distinct between the range of models available.  Even the lack of standard uniformaty between model numbers, (ie the W8 series ends with W805/W807 and the W6 is W653/W654)
Hi there
jowhale
Great, thanks for this. I had a feeling it would be something simple. Pity they don't add that field in the Spec page!
Sent from Samsung tablet
