Solved! Go to Solution.
Brilliant - glad its working again. You;re Welcome and have fun
Can you tell me how to do this? I am having the same exact problem.
For anyone with this issue, it appears that Sony/Opera are forcing you to allow ad.doubleclick connections. Usually if you have a gateway level ad blocking enabled (Diversion etc), connections to these sites will intensionally be routed to a localhost. Very annoying and not acceptable in my opinion. However, it can easily be resolved, by manually setting your DNS servers on your TV (in Network Settings, Custom Connection, Manual IP address) to Google's DNS 8.8.8.8 / 8.8.4.4 servers for example, rather than your own gateway. This will allow ad.doubleclick connections and not create the YouTube app to overlay the error. Hope this helps.
