youview on KDL-49WD756
barryod1974
Hi
I have recently purchased a sony tv, model # KDL-49WD756. I cannot get Youview to work and think it may not be available for this model, however the shop who delivered it is adamant it should. I feel like im banging my head of a brick wall, Can anyone confirm whether youview should be available on this model as i bought the tv in the advice of the sales guy.
Regards, B
Hi there
Only Android based Sony TVs in the UK have YouView.  Unfortunately the WD75 series TV is linux based and not Android, hence the reason why you cant enable YouView.
I think you will need to go back to the retailer if you believe you was mis-sold.
barryod1974
Thanks Quinnicus
That saved a lot of hassle. The local shop have been fine and have upgraded to a 50" android tv at no additional cost (even though it is more expensive).
