2 BIOS Updates but..
johnyVAIO
Two BIOS Updates but which is the right one?? using VPCCW1S1E.
1. BIOS Y5 R0190Y5
2. BIOS R0190Y5
johnyVAIO
takrzem
They do look the same to me.
The best is to download both and simply compare files.
johnyVAIO
what to compare except the file size and release date? i dont wanna mess with the bios soft. logically the most recent file, its the right one to install if both the files are meant for the same bios
johnyVAIO
the file size is the same but the dates not.
see http://www.sony.co.uk/support/en/product/VPCCW1S1E_B/updates
i have installed BIOS  - R0190Y5 which is from 2009.
