2 Hard drives
nellmad
2 Hard drives
I have just bought a new laptop, and I have never had 2 hard drives before. I have a C drive and a D drive, I have tried to save stuff on my D drive but it won't let me, all I have on the D drive is a sonic folder which is empty and a video folder which is also empty, my C drive is nearly full,can anyone help by explaining what the D drive is for, I am a novice, so be gentle with me.
Thalamus.
Champion
Hi nellmad,
Welcome to Club Vaio, :slight_smile:
I suspect that you only have one hard drive on your Vaio that has been partitioned into C: & 😧
If you goto Start > Control Panel > Performance and Maintenance > Administrative Tools > Computer Management.
A new window should open, then click on Disk Management in the storage section, you should now see how many Disc's (hard drives) you have and how they are partitioned.. :slight_smile:
If you open 😧 from My Computer are you able to create a folder..?
The D drive can be used for any purpose, but it may be a good idea to use this partition to store data, etc. such as your documents. You can move your My Documents folder to D by following this guide.
