Hi...
I've god VAIO VGN-FE31M. I would like upgrade RAM from 1GB (2x512MB) to 4GB (2x2GB). Do you have any experience for this one ??? I found some modules on this webpage:
http://www.pimspcshop.nl/
And there go to 'Notebooks', then 'Geheugen [Notebook]', then mke choice for view 'Toon: Lijst' and you can find this list :
Kingston SODIMM Voor Toshiba 2048 MB, PC4300, 533 MHz, KTT533D2/2G € 137,49
Kingston M6464A30 512 MB, PC133, 133 MHz, M6464A30 € 81,37
OCZ Notebook Memory DDR2 512 MB, PC5300, 667 MHz, 5 € 78,69
Dane-Elec SODIMM Voor HP 256 MB, PC100, 100 MHz € 67,32
Kingston ValueRam 128 MB, PC4200, 533 MHz, 2, KVR533D2S4/128 € 47,46
Kingston M3264A30 256 MB, PC133, 133 MHz, M3264A30 € 38,37
Kingston ValueRam 1024 MB, PC6400, 800 MHz, 5, KVR800D2S5/1G € 35,99
OCZ Notebook Memory DDR2 1024 MB, PC5300, 667 MHz, 5 € 28,54
Kingston ValueRam 128 MB, PC3200, 400 MHz, 3, KVR400D2S3/128 € 27,72
Corsair VS1GSDS667D2 1024 MB, PC5300, 667 MHz, 5 € 27,66
G.Skill SO DIMM DDR2 512 MB, PC5400, 675 MHz, 5, F2-5400PHU1-512SA € 25,16
Kingston ValueRam 128 MB, PC66, 66 MHz, 3, KVR66X64SO/128 € 22,63
Kingston ValueRam 128 MB, PC100, 100 MHz, 2, KVR100X64SC2/128 € 20,40
Kingston ValueRam 512 MB, PC6400, 800 MHz, 5, KVR800D2S5/512 € 19,12
Corsair VS512SDS667D2 512 MB, PC5300, 667 MHz, 5, VS512SDS667D2 € 17,21
OCZ Notebook Memory DDR2 Dual Channel 4096 MB, PC5400, 675 MHz, 5, OCZ2MV6674GK € 194,82
Kingston SODIMM Voor Toshiba 2048 MB, PC5300, 667 MHz, Non-ECC, KTT667D2/2G € 138,73
Kingston SODIMM Voor Fujitsu-Siemens 2048 MB, PC5300, 667 MHz, Non-ECC, KFJ-FPC218/2G € 138,73
Kingston KTH-ZD8000B/2G 2048 MB, PC5300, 667 MHz € 137,49
G.Skill SO DIMM DDR2 2048 MB, PC5300, 667 MHz, 5, F2-5300CL5S-2GBSA € 134,63
Kingston ValueRam 1024 MB, PC4200, 533 MHz, 4, KVR533D2U4/1G € 132,60
Corsair VS2GSDS667D2 2048 MB, PC5300, 667 MHz, 5 € 103,94
OCZ Notebook Memory DDR2 2048 MB, PC5400, 675 MHz, 5, OCZ2MV6672G € 99,96
Dane-Elec SODIMM Voor Apple 2048 MB, PC5300, 667 MHz, Non-ECC, DA-MBP667-2GB € 89,76
Kingston Valueram 2048 MB, PC5300, 667 MHz, 5, KVR667D2S5/2G € 87,82
Kingston ValueRam 2048 MB, PC4200, 533 MHz, 4, KVR533D2S4/2G € 86,65
Dane-Elec SODIMM Voor HP/Compaq 2048 MB, PC5300, 667 MHz, Non-ECC € 82,62
Dane-Elec SODIMM Voor Apple 2048 MB, PC5300, 667 MHz, Non-ECC, DA-MBP667-2GB € 82,62
Dane-Elec SODIMM Voor Compaq 512 MB, PC133, 133 MHz, DA-251653-B21 € 76,91
Kingston ValueRam 1024 MB, PC2100, 266 MHz, 2,5,KVR266X64SC25/1G € 74,45
Dane-Elec SODIMM 1024 MB, PC2700, 333 MHz € 73,43
Dane-Elec SODIMM Voor FUJITSU-SIEMENS 1024 MB, PC2700, 333 MHz € 73,24
Kingston ValueRam 1024 MB, PC2700, 333 MHz, 2,5,KVR333X64SC25/1G € 70,23
Corsair VS2GSDSKIT667D2 Dual Channel 2048 MB, PC5300, 667 MHz, 5 € 67,32
Corsair VS1GSDS333 1024 MB, PC2700, 333 MHz, VS1GSDS333 € 65,08
Dane-Elec Toshiba Compatible P200 Series 1024 MB, PC5300, 667 MHz, DA-PA3512U-1M1G € 42,84
Kingston SODIMM Voor Toshiba 1024 MB, PC5300, 667 MHz, KTT667D2/1G € 41,82
Kingston KTM-TP3840/1G 1024 MB, PC4200, 533 MHz, KTM-TP3840/1G € 41,82
Kingston SODIMM Voor Toshiba 512 MB, PC2100, 266 MHz, Non-ECC, KTT3614/512 € 41,82
Kingston KTH-ZD8000B/1G 1024 MB, PC5300, 667 MHz € 39,69
Corsair VS1GSDS533D2 1024 MB, PC4200, 533 MHz, 4, VS1GSDS533D2 € 36,34
Kingston ValueRam 512 MB, PC2100, 266 MHz, 2,5,KVR266X64SC25/512 € 28,56
Kingston ValueRam 512 MB, PC2700, 333 MHz, 2,5,KVR333X64SC25/512 € 28,56
Kingston SODIMM Voor Acer 128 MB, PC100, 100 MHz, M1664002 € 27,54
Dane-Elec SODIMM 1024 MB, PC4200, 533 MHz, S2D533-06428-D € 26,52
Dane-Elec SODIMM Voor Acer 1024 MB, PC5300, 667 MHz, Non-ECC, DA-LC.DDR01.011 € 26,52
Dane-Elec SODIMM Voor Sony 1024 MB, PC5300, 667 MHz, DA-VGP-MM1024M € 26,52
Dane-Elec SODIMM Voor DELL 1024 MB, PC4200, 533 MHz € 26,50
Transcend SO-DIMM 1024 MB, PC5300, 667 MHz, 5, Non-ECC, 64Mx8 € 25,19
Kingston ValueRam 1024 MB, PC4200, 533 MHz, 4, KVR533D2S4/1G € 24,48
Kingston ValueRam 1024 MB, PC5300, 667 MHz, 5, KVR667D2S5/1G € 24,43
Kingston DIMM For IBM/Lenovo 512 MB, PC5300, 667 MHz € 23,70
Kingston DDR2 Voor Toshiba 512 MB, PC4200, 533 MHz, KTT533D2/512 € 22,44
Kingston ValueRam 256 MB, PC2700, 333 MHz, 2,5,KVR333X64SC25/256 € 21,42
Kingston KTH-ZD8000B/512 512 MB, PC5300, 667 MHz € 21,16
Corsair VS512SDS533D2 512 MB, PC4200, 533 MHz, 4, VS512SDS533D2 € 20,40
Kingston ValueRam 512 MB, PC4200, 533 MHz, 4, KVR533D2S4/512 € 14,27
Kingston ValueRam 512 MB, PC5300, 667 MHz, 5, KVR667D2S5/512 € 12,51
Kingston ValueRam 128 MB, PC2100, 266 MHz, 2,5,KVR266X64SC25/128 € 12,24
Kingston ValueRam 128 MB, PC2700, 333 MHz, 2,5,KVR333X64SC25/128 € 11,29
Infineon SODIMM 256MB, PC 2100, 266 Mhz, 2 (Demomodel) € 7,95
Witch module is right or best for me ???
Here's my VAIO configuration:
Memory Controller Information
Memory Controller : System Memory
Error Correction Capability : No
Number of connectors : 2
Max. Module Size : -2097152 KB
LPC bus Yes
Chipset Intel i945PM
General Information
NorthBridge : Intel i945PM
SouthBridge : 82801GBM (ICH7-M) LPC Interface Controller
NorthBridge Information
Architecture : Direct Media Interface (DMI)
Manufacturer : Intel (Sony Corp)
Codename : Lakeport
Revision : A3
Bus Speed : 166.2 MHz
FSB Frequency : 665 MHz (QDR)
FSB max. Support : 667 MHz
RAM max. Support : DDR2 (667 MHz)
I'll be thankeful for any helpful response...
Miro
Hi slnko and welcome to the forum.
The FE31M only supports 2GB RAM max (1GB per slot).
I recommend that you have a look at Crucial.com for the best (and guaranteed memory of your system.
Thank you for your answer.
I found some information from INTEL webpage about Mobile Intel® 945PM Express Chipset. There is:
Dual-channel DDR2 667MHz Memory Support Up to 10.7GB/s of bandwith and up to 4GB memory addressability, for faster system responsiveness.
http://www.intel.com/products/chipsets/945pm/index.htm
Then how did you get ''The FE31M only supports 2GB RAM max (1GB per slot).'' ?
And at Crucial.com I'd find no 2 GB DDR2 RAM modules in their offer.
Thank you for help to solve my thing.
I found on Crucial link from Vaio-Link discrepancy about RAM and upgrate. There stay:
Memory 1024 MB (Upgradeable to 2048 MB)
Memory Information SO-DIMM 533Mhz (DDR2)
But at
http://vaio.sony.nl/view/ShowAccessorySeries.action?site=voe_nl_NL_cons¤tProductCategory=Memor...
is recommendation for Model Category FE Module SODIMM DDR2 SDRAM with 667 Mhz (VGP-MM1GA). And sony.uk offer no one module for FE models. For me it's a bit confused. Is it right freq. 667 or 553 Mhz ???
I thing 553 mhz is actual freq. and 667 is also supported by motherboard (source INTEL).
And second point is about Upgrade at
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2404&site=voe_en_GB_cons
There is Maximum Memory 2048 MB with Memory Type SO-DIMM - 533Mhz (DDR2) . But no sign, for one module or for two modules ? And again here is question about 533 or 667 Mhz ???
Descrease trust to the sony web.
No you wouldn't because each slot will only accept a max. of 1GB. Hence they offer a 2GB kit (2 x 1GB).
The 667Mhz module is backwardly compatible, so even if your motherboard can only handle 553Mhz these modules will work fine with your system but at the reduced speed.
But they do offer no one DDR2 module with 2 GB (2x2GB). That's the point, I thing.
Hallo,
I've got 4 gb ram instaled with succes in last few years. But now is problem with windows7 64bit. Till now I had 32bit Vista. Win7 have usable only 3gb ram. I can't change it in bios. But I would like to use 4 gb ram.
Any suggestion?
