8400M GT Driver for Vista 64b VGN-FZ21M
Johnnybe
Hello,
I have upgraded my VGN-FZ21M from Vista 32b to Vista 64b.
Unfortunately, Sony doesn't provide the driver for the 8400M GT under Vista 64b and Vaio's are locked on Sony drivers only.
I have looked everywhere and called every contact support in vain.
Does a list of drivers exist? Could I use a driver for another model that runs Vista 64b on a 8400M GT by default and if so which model might that be?
Thanks a bunch,
J
rich912
Hi Johnnybe,
If you are unable to find a Vaio with the same GPU that has Windows 7 64-bit Win 7 upgrade driver then you will need a modified .inf file in order for the nVidia driver to be recognised and installed.
Have a look at the following link – be sure to read the ‘Quick Start Guide’ towards the bottom right.
http://www.laptopvideo2go.com/drivers
Rich
Go n-éirí an bóthar leat
