I bought the VGN-SZ1XP/C last week (2800 euro!) but I have a lot of problems: conflict between NVIDIA graphic card and some softwares (eg: antivirus NOD32, ESRI software like Arcgis), conflict between mousepad and mouse USB (like 10 years ago with some old notebooks!), conflict again between mousepad and wireless keyboard! All with "deep blue death" screen and reset of the notebook.
Anyone with same problems?
Any solution?
Sanazz, i've read in some american forum that mora people have the same problem, so it seems to be a design problem... Do you also have the same problem with the Optical Drive? Try to insert a CD and move the laptop a bit when copying some files from the cd. Dont shake it, just try to pick it up with one hand or something like that.
Im still waitng for the eSupport guys, lets see what they say about the keyboard and the CD.
You shouldn't move the laptop when it's reading from the hard disk or DVD drive
my space key is OK
annoynig
I'm having the same problem. Initially I thought it's me not getting used o the keyboard, but after a brief search on the web I found that many ppl worldwide share the same problem with SZ laptops. My spacebar key doesn't work unless I hit it right in the middle. It won't work if I hit it at the edges or within 3-5cm of the left/right edge (problem more serious on the left hand side). It's extremely annoying as it fuses words I type and messes up Perl scripts I write! As if I can't type properly!
Hello!
I've just posted a note about this spacebar problem on another thread here. I'm having the same problem. I don't know what to do. I've been in contact with the support but they're not sure what to do yet.
Did anyone get help for this problem?
/Johannes
Hello!
Ah - the wonders of modern technology. What did we do before 'Post It' stickers!
Could anyone got any ideas where to download Nvida GeForce Go 7400 new driver?
