hi there i was having trouble with my vaio kept crashing and stuff anyway ,i used the recovery cd to clean everything off and start again but i found i dont have all of the software back for instance the adobe premier the dvgate and all of that how can i retrieve all of that back my laptop model is the pcg-grt895mp
That should be on the last disk of your recovery set.
Did u manage?
I had the same problem and no way to find the software 😞
