AC Adapter not working
rokilne
I have a 3 year old VAIO VGN NR10E/S and the AC adapter has suddenly stopped working. There’s 220v going into the adapter and nothing coming out, and the green LED has stopped glowing. The laptop indicates that it isn’t charging.
Is it worth trying to get it fixed? Should I just look online for a replacement?
Thank you for any help you can offer.
rich912
Hi rokline,
As a genuine AC adaptor will cost as little as £25 I doubt that a repair, if possible, would be economic.
Have a look here.
http://www.amazon.co.uk/VGN-NR32MS-VGN-NR21ST-VGN-NR31JS-VGN-NR21ZS-VGN-NR11SR/dp/B003EGOK0I
Go n-éirí an bóthar leat
rokilne
Yes I see what you mean -- I think I'll just go ahead and order a new one.
Thanks for your help.
profile.country.fr_FR.title
nethead
most of the time it's one or more capacitors to change  Myadvice , buy a new one unless you are short of money.
