AC Adaptor Q.
XiOnce
AC Adaptor Q.
Q. I have recently broken the  Adaptor for my laptop and i need to buy a new one ASAP!!!!! but how do i  know if the new adaptor is compatible with my laptop which is  VGN-FW11M?!?!!? how do i know what type of adaptor to buy?!?!?
the broken adaptor spec is 19.5V  (INPUT: 100-240V 1.3A 50-60Hz OUTPUT 19.5V 4.7)......VGP-AC19V24.
2 ACCEPTED SOLUTIONS
Thalamus.
Champion
Hi XiOnce,
you should be able to purchase a replacement charger from Vaio  support or possibly from one of Sony's authorised repair partners, to  find the contact number for Vaio support.
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab, then Phone support.
Or
To locate the nearest Sony service partner click on Out of Warranty Service tab
Thalamus.
Champion
Hi XiOnce,
Then click Log-In
Or
Thalamus.
Champion
Great find Blencogo that would probably be a lot cheaper..
