Access Advanced BIOS Menu? - SVF1521A2E
I see that hyperthreading is supported but disabled, how do I enable it in the BIOS? Also if anybody can tell me the specifications of the motherboard, that would help as well.
Thanks!
Ah well, how disapointing the main useful parts of the Advanced Menus are loackd away from the end-users grasp. I contacted Sony and they are having none of it (unlocking all the hidden features) - bios sites are having problems as well as they are getting...
Error 28: Protected Range Registers are currently set by BIOS, preventing flash access.
Please contact the target system BIOS vendor for an option to disable Protected Range Registers.
Booo! 😞
/might give Insyde a mail, but they don't like end-users either!
