Adding extra memory
ZyRaIN
Adding extra memory
I want to add 512mb of memory to my A117s, I just took a look on the back side and can see that there is only 1 slot and it is full :slight_smile: I've got 512 in total know how do I upgrade this to 1gb.. ?
5 REPLIES 5
spider.s3
there is 1 under the keyboard too.
ZyRaIN
So I should deattach the keyboard ass well ?
spider.s3
link
look at the link
ZyRaIN
Thanks for your help.. :slight_smile:
do you know if I can use pc3200 ? and not the pc2700 which standard are in ?
spider.s3
i don't think so as PC2700 runs at 333Mhz. and the PC3200 runs at 400Mhz.
All the sites i have been to say that you should only use PC2700 in them.
If i am wrong would someone please tell me.
