Adobe Premiere Pro 1.5
irishpureblood
hi does any on have the same problem i have used the vaio Adobe Premiere verison and it works perfect but in stalled Adobe Premiere Pro 1.5 and it really slow and captureing is not as good ....any tips would help
kee-lo_
I would uninstall the VAIO version and install the Pro version you bought
irishpureblood
i install win xp pro complete format and then installed Adobe Premiere Pro 1.5 stii the same problem
kee-lo_
I would ask Adobe Support
