Although I have added my printer to my computer, I can't print unless the USB cable is attached. Please help.
Brenda22
Although I have added my printer to my computer, I can't print without the USB cable being attached. Can anyone help?
Have you followed this tutorial for setting up the wireless printer?
http://resources.kodak.com/support/pdf/en/manuals/AiOPrinters/ESP_Series/ESP-Printer-NSG_en.pdf
Have you installed the Kodak All-in-one Printer software on your Vaio?
:thinking:
Which Printer do you have? Exact Make and Model please.
Which Vaio do you have?
Is the printer WiFi enabled or is it Network enabled.
What have you tried?
:thinking:
Brenda22
Hi
My notebook is VPCEE3EOE and my Printer is KODAK ESP9 AIO. I have wifi using NETGEAR. The printer is showing as my default printer and prints perfectly when the USB cable is attached. There is another laptop using the printer without a cable. I have followed all the troubleshooting advice for a few months now without success and am very frustrated with it. I am sure it must be something basic!
:thinking:
