Am I Blind??
Nygie
Am I Blind??
Is there a search function for the forum?
No you are not blind .......... well I hope not!
....... sadly there is no search until the next Forum Upgrade.
In the meantime just ask and someone will help point you in the right direction - or you can try the Google workaround but it is less successful than simply asking the question here.
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=59606
:slight_frown:
