an unhandled exception occurred in a 3rd party module and will be closed
diwisem
I get this error message 2 or 3 times a day on my wireless connection.Then the web page closes down and then opens again within seconds.Can anyone explain to me why this happens.Thanks.
rich912
Hi diwisem and welcome,
It could be a problem with a tool bar or add-on.
Assuming that you are using Internet Explorer, try restoring to default settings – In Control Panel open Internet Options and then click on the Advanced Tab. Click “Restore Advanced Settings” and then click on “Reset”, make sure that “Delete personal settings” is unchecked and then click the Reset button.
The procedure may vary slightly if you are running Windows 7 as opposed to Vista.
Go n-éirí an bóthar leat
