Is there anyone using Wanadoo'd Livebox to connect wirelessly to a Sony laptop with an Intel Pro/Wireless 3945ABG network adapter? I have an SZ1XP which wont connect except using the USB adapter or ethernet method. If you have managed to surf please report all the settings of the adapter within the Windows XP/SP2 operating system including the TCP/IP settings etc.
thanks
i have a pcg-k315z and found a way to connect. What i don't understand is that you can connect it with cable (realtek rtl8139/810x).
Mine works with borh (including the LAN-Express AS IEEE 802.11g miniPCI Adapter).
