AR11M - analog video capture
hidesil
I want to capture some old VHS tapes with my AR11M. I see there is an S-Video input socket on the right hand side of the laptop. What software should I use to capture analog video?
I have Abode Premiere but the options for video sources seem to be DV and HDV only.
Thanks for any help.
Have you tried Click2DVD and set it to analogue capture?
You may find the AV Input (left of the S-Video input) easier to use as this will include Audio L, Audio R and Composite Video. You will need a cable like this one: -
3.5mm Jack to 3 X Phono (4-Pole)
:wink:
