Hi to everyone,
I have a problem unfortunately :(,
I have a sony vaio VGN-AR21S ,
I have installed the windows vista 64 bit but
unfortunately i can't install the webcam drivers motion eye (Ricoh R5U870 😞 ).
I have forced installing the ar31s driver windows recognize it but doesnt work :(.
Can someone please tell me where to download these drivers ?
Best regards,
Thank You for your help.
Siggy.
The drivers are camera specific and usually work on any OS.
I would try installing the correct driver for your camera (The original Ricoh XP driver for the VGP-VCC2) as this is the only driver that will work. You may have to try compatibility mode.
However, it may not work for 64-bit and as far as I can see a driver specifically for 64-bit does not seem to exist.
I attach the VCC2 driver. You will need to extract the file and install the driver from Device Manager using the 'Have Disc' method and pointing the installer to the 5U870CAP.INF file
thank you for your help but,
this driver are for 32 bit OS my vista 64 bit reefuse to install it because they are not 64 bit but 32 😞 I have tried also "have a disk procedure" like you said pointing the inf but nothing to do 😞 error is that driver is not 64 bit 😞 we need untortuanetely a 64 bit driver.
please sony help :).
