Hi I just bought this and upgraded the memory to 4gb but vista only shows 3070. will this laptop take the vista 64 bit upgrade or do i have to get the full 64 bit retail to use 4gb ram?
also i lost the screw to the memory cover anyone know where i can get a replacement?
regards
Hello,
To the full 4 GB to be able to use it, you will need a Windows Vista64 whether the upgrade version, or as normal as the vista 32bit not supported 4 gb
H0RUS
Hi pb21,
But there is a problem with Sony support for Windows 64-bit, see here...
http://www.vaio-link.com/os/vista/64bit/
As said, Vista 32 bit has a maximum memory usage of 3mb. personally, i'd stick with 32 bit and put up with the loss of 1gb.
Better still, downgrade to XP and have a REALLY fast PC!
Sony do say in the specs of there laptops that you wont get 4GB >>>>> 2 GB DDR2-667 SDRAM (2 x 1024 MB - No free slot available), maximum 4 GB DDR2-667 SDRAM - in the case of 4GB, a portion of the system memory over 3GB might not be available to the operating system <<< thats what they say in all there laptop specs.
its not really a major problem so dont worry about it its completely normal
