Arcsoft Visual Effects 2 HD
profile.country.nl_BE.title
Nikotine
My Sony Vaio SPCSE1C5E came with the Arcsoft Visual Effects 2 HD software. Because I had issues with my webcam I reinstalled all webcam related software. The Arcsoft Companion software can be found on the drivers and software download page, but for the Visual Effects software I can't find a link.
How can I reinstall this?
rich912
Hi Nikotine,
Have you looked in Vaio Recovery Center > Reinstall Programs or Drivers to see whether the software is listed as available for reinstall?
Rich
Go n-éirí an bóthar leat
Nikotine
Yes, I've checked but unfortunately it isn't there.
rich912
Due to licensing agreements some preinstalled software can only be reinstated by carrying out a factory recovery using either your recovery disks or the hidden HDD recovery partition.
Unless anyone knows any different I would assume that this applies to Visual Effects.
Rich
