Hi guys, I recently found out about the AV Mode, where you can listen to music and watch DVD's without actually booting Windows. So when I press the AV Mode button whilst my computer is off, it just boots Windows, this is probably something simple but thanks for your help
I have a AR41E by the way.
Hi .naVA.
AV Mode is different from "InstantON Mode". I'm afraid you don't have the InstantON feature on your AR-Series.
In Europe, only the CR-Series and the TZ-Series have this InstantON feature that can be used without booting into Windows. In the USA the FZ-Series also has it but not in Europe.
The AV Mode only allows you to pre-select a player from within Windows for displaying media - worse than useless!!
EDIT: Evening Thalamus - too quick for me again!!
:smileyblush:
