Base System Device yellow triangle vgn-aw11s
deeman1911
I have a a yellow triangle in the device manager against the base system device on my vgn-aw11s can you tell me what file to use on windows 7 to fix this.
Hi deeman1911.
It is probably the Memory Stick/SD Card slots but you can check in Device Manager -> Propeties - Hardware IDs.
There is no driver specifically for Windows 7 so you will need to try the Preinstalled Vista MemoryCard Drivers (I think there are 3 drivers for MS and SD) under the Preinstalled Vista Tab here: -
http://www.sony.co.uk/support/en/product/VGN-AW11S_B/updates
:thinking:
Hi deeman1911.
:thinking:
