Battery Icon on taskbar isn't there
Pat_D
Hi all,
I have a FE-31m notebook, and I used to have that nice battery icon on the taskbar. Now it is gone and I do not know how to get it back. Rightmouse on taskbar and selected the icon must always stay there (so it won't hide) but that didn't work.
Under energysettings, clicked on the thingy which says to show the icon also always on the taskbar, still nothing.
Anyone ideas how to get it back :)?
Thanks,
7 REPLIES 7
Pat_D
No ideas at all?
Thalamus.
Champion
Hi Pat_D
does the icon reappear if you restart your Vaio..?
I'm afraid it is a common problem.
This link is very informative: -
http://winhlp.com/node/16
:wink:
Pat_D
Hello,
Well, this is actually the first time that I have this problem.. I've reinstalled my vaio a couple of times and everything was fine. Until now. I'll take a look at the link, thanks.
And after restart, the icon doesn't appear.
Thanks,
Pat_D
Hello,
I read the article, and I have fixed the problem. In my network places, I clicked on hide UPnP devices, rebooted and the icon is back. Thanks for the help all :D!
But still, it is weird that the icon disappeared.
Thanks all :)!
Hi Pat_D,
Good news!
The 'Disappearing Icons' trick has been a constant bug in XP for years. Glad you've been able to fix it.
:slight_smile:
Thalamus.
Champion
Glad you've solved your problem Pat.. :slight_smile:
