Battery problem
zhengou
Battery problem
I just bought a Vaio Z11/MN, to be frank, I like it. However, I found a problem with my battery. For example, I charged the notebook 100% when I turned it off. But 2 days later, when I turned it on, it showed that battery had only 58%. Is it normal? Is there someone who is kind enough to explain it to me? thanks in advance.
Zhengou
profile.country.pt_PT.title
luisarn
Zhengou
Hi, did you turned it off (shutdown) or put it in sleep mode?
For the battery to drain to 58% I guess it was in sleep mode otherwise I guess there's a problem with the battery.
Btw, how many times did you fully charged the battery? The battery only reach its maximum charge after a couple of full charge when it is still new.
