farraway
BATTERY
I HAVE A NEW VAIO DUO11 (3 DAYS OLD) AND THE BATTERY INDICATOR ON THE DEKTOP SHOWS "PLUGGED IN, NOT CHARGING". DO I HAVE A FAULTY BATTERY
rich912
Hi tonyjfarrell,
Is the battery working when you disconnect the power adaptor?
What % capacity is the battery showing?
Do you have Battery Care enabled - Vaio Control Center > Power Management > Battery Charge Functions?
Rich
Go n-éirí an bóthar leat
