BIOS replacement... URGENT!!
Karla.Mazurek
My father bought old Vaio PC and he really needs to replace BIOS (of course he was playing with it which lead to destroying the file)
specifications:
PN--28472253-product code
PCV-RX417D-Model
D4170/2AH016.00230
ACPI BIOS REV.1001-P4S533VX-08/20/2002
SST 49LF020
So what I need is a gle1001.bin file...
Edit by Rich912
8 REPLIES 8
kee-lo_
I have forwarded this onto VAIO-Link, as the files don't seem to be on the website?
Thalamus.
Champion
Hi Karla.Mazurek ,
Welcome to Club Vaio, :slight_smile:
As this is a public forum it may be a good idea to edit your message and remove your serial number from your post.. :wink:
jammold
Oh and remove your service tag as well, only you and Sony should know that number :wink:
kee-lo_
Good point James, but I can't say I read it all because I knew it was irrelevant.
Karla.Mazurek
Anyway... it's my fathers computer :slight_smile: I've got Fe11h :slight_smile:
I know... that was stupid...
Karla.Mazurek
Would you mind posting the file in here? I'm not very experienced with Vaio link and Vaio forums... I still haven't managed to repair that bios
Bios models from Rx420 to RX480 would suit this.
I would really appreciate your help
kee-lo_
Sorry Karla I don't have access to VAIO Link resources as I'm just a volanteer - I'll ask again....
Edit: Interesting you can't call VAIO-Link twice.... damn
profile.country.de_DE.title
seb21__
If the board is allready unusable because of the destroyed BIOS, then you could try the original BIOS from the board manufacturer.
However, you will lose your warranty (should be over, allready) and support by Sony VAIO Link. I bet your recovery disks won't work too. (but there are work arounds)
And there is no warranty that it will work correct.
